Sign-in / Sign-up
Hdd led power sw power led reset sw
  • Homebuilt
  • LED Monitor
  • Power
  • Hard Drives
  • Systems
Last response: in Systems
Anonymous
a b B Homebuilt system
August 21, 2010 11:13:04 AM
i have put all my front panel wire correct but the hdd led flashing on the power switch plus reset button does not work and the power led light is knot on right i have tried every possible routes but this only way i have set it work can you help
More about : hdd led power power led reset
Anonymous
August 21, 2010 12:04:57 PM
This topic has been moved from the section Windows Vista to section Systems by Grumpy9117
m
l
August 21, 2010 12:38:15 PM
Can you post your case model and motherboard model numbers please,
people will be more likely, able and inclined to help you.
Moto
m
l
