Solved
GTX 460, GTX 470 AMP by zotac, or 5850?? help!!!
I cant make my mind! :(
My budget is somewhere from $300 to $365
Ive been thinking about the GTX 460 since so many people seem to like it, but i want to get the BEST performance i can for my particular resolution (1920*1200).
I've been looking newegg for sooo long and i've narrowed it to this bad boys:
GTX 470 AMP by Zotac. With a triple slot cooler.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814500167&Tpk=gtx%20470%20amp
Gigabyte's 5850 with double fan and custom cooler.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125318&cm_re=5850-_-14-125-318-_-Product
XFX'x 5850
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150477&cm_re=xfx_5850-_-14-150-477-_-Product
Palit's GTX 460 Sonic platinum
http://www.newegg.com/Product/Product.aspx?Item=N82E16814261075&cm_re=gtx_460_1gb-_-14-261-075-_-Product
As stated before, i want to get THE BEST performance posible but i cant seem to figure out wich card to get :sweat:
I now have a GTX 260 by zotac and it's been wonderfull! and watching that AMP! edition just makes me drool!
The 5850 by Gigabyte looks amazing to! a friend of mine has a 5870 with the same cooler and it does an outstanding job!
The XFX has a lifetime waranty!
And the Palit card is the king among the 460's!
YOU SEE?!?!?!
HELP!!! :lol:
7 answers Last reply Best Answer
More about zotac 5850 help
  1. I myself would not put a Palit or Zotac anything in my computer so XFX or Gigabyte win on brand alone. Just read those newegg reviews on the Palit card. Wait for Asus or XFX 1Gb models with voltage control if you want a GTX 460.
  2. Best answer
    The answer to that question is quite simple. Of the three cards you are looking at the GTX 470 is the fastest. That particular model however is way more than you need to spend. For very little more you can get an HD5870 which is a better card;
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814150490
    well THAT is the best answer!!!!!
    Thank you so much for your help!
    It will be a 5870 :love:
  4. Best answer selected by gerardb.
  5. yeah , 5870 !
  6. how about 2x GTX460 than a 5870??
  7. 2 1gb GTX 460s would be $460 well over the guys stated budget.
Graphics Cards Gtx Zotac Cooling Graphics Product
