The 120gb Sata-II SSD I currently run Win 7 on is getting low on space. I would like to add another SSD, of the Sata-III 6GB/s variety, that can be used to run Win 8 (or Win 7, and then put Win 8 on the Sata-II SSD I mentioned), and thus have Win 7 and Win 8 running in a dual-boot config.
It should be noted that I have:
- ASUS P6T mobo, which only has Sata-II ports, all of which are being used.
- Both one PCI and one PCI-X 16 slots to work with (ie. they're open).
- Only those "older" red Sata cables, which I presume won't support a Sata-III 6Gb/s SSD.
Given my situation, my assumption is that I'll need:
- A PCI-X (preferable to just PCI) Sata-III card with at least two internal ports (4 would be nice).
- One of those 3.5"-to-2.5" HDD kits to hold the two SSD's securely.
- At least one Sata-III 6Gb/s Sata cable to connect the Sata-III SSD I'll be buying to the port on the Sata-III PCI-X card.
Are the above assumptions correct? If so, can anyone recommend matching products, especially for the PCI-X Sata-III card?
Please let me know if I'm overlooking something or generally being a buffoon. Thanks in advance!
