I have a GTX 480 card on an Big Bang-XPower (will have as soon as components arrive). I have now decided to get another GTX 480 for a GTX 480 SLI configuration (Both MSI GeForce GTX480 1536MB DDR5 (PCI-E)).
Air-cooling is the only option acceptable to me. I have ordered an Cooler Master HAF-X.
What I would like to know is if there are any replacement fan radiators to replace the one that comes with the 480, if so what would be the best (3x fan radiator would be my preference - running at lowest possible RPM's). Note that the Mobo runs x16 x16 SLi in slots 1 and 4, so space will not be an issue.
Thanks for your attention.
