Hi, ive recently come accross something completely baffling on my computer. I tried using 2 different cables that looked fine with the correct pins and neither of them work. I had a look at the one i have in that does work, and it appears all the pins are in the wrong order .
instead of pin 1 being orange/white, it is brown. The pins are in the correct order, but they start at the wrong pin. So for some reason a cable that is backwards works, but 2 cables with the correct pins dont work. Any help?
