Compatible power supply
Thanks for humoring my newb question.
I think my power supply may be going out and was wondering how to tell what power supply units are compatible with my system.
I have an:
Antec P180 Mid-Tower- 450W PSU
ASUS P5N-E motherboard LGA 775
Intel Core Duo 6600 Dual Core
Kingston HyperX 4gb (4x1)
eVGA Geforce 7600 GT KO
WD 74GB Raptor
Seagate 1TB data drive
Seagate 500gb data drive
CD/DVD combo
DVD burner
Speakers
I was thinking of going up to a 650W power supply. Used for Heavy Photoshop, listening to music, watching movies, and streaming videos on the web. How do I know what is compatible. Anyone have any recommendations for Power Supply Units?
Thank You!!!
6 answers Last reply
More about compatible power supply
  1. It will accept ATX PSU. Here< is a good one in the size range you are talking about http://www.newegg.com/Product/Product.aspx?Item=N82E16817151096
    There 520watt unit would be plenty for your system though http://www.newegg.com/Product/Product.aspx?Item=N82E16817151094
  2. any modern antec, seasonic, silverstone, enermax, corsair, or ocz will work for you. None of the hardware you listed requires a lot of power. If you don't plan on getting a power hungry video card then 400w+ is plenty for you. It will power your PC and let you install most mid-tier gaming cards.
    this corsair 430w is a solid unit
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139017&Tpk=corsair%20430w
  3. Thanks rolli59 and ct1615!
  4. Quote:
    upgrade your video card while your at it..
    malmental,
    Why do you suggest upgrading my video card? Do you think I really need it for Photoshop and watching videos/streaming??
    Thanks for your time!
  5. its fine for those duties
  6. @mal Not everyone on here is bothered about having the most powerful PC they can afford. OP asked about PSUs, not graphics card.
Power Supplies Compatibility Components Product
