Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > CM PSU making electrical buzzing sound
Forum CPU & Components : Power Supplies, Cases & Mods CM PSU making electrical buzzing sound
Just bought a brand new CM GX 750W PSU, after 2 days of use, an on and off electrical buzzing occurs, it's not constant. But after i shut down the com a less loud buzzing sound is heard from the psu I'm sure of it.It's non-stop, i have to switch off the main socket to eliminate the noise. What is happening?
Message edited by areszues92 on 11-10-2010 at 04:49:09 PM
Reply to areszues92
you bought a crappy brand of power supply and should return it.. for something decent.
http://www.jonnyguru.com/modules.p [...] y&reid=188
Message edited by rand_79 on 11-10-2010 at 05:38:09 PM
Reply to rand_79
The brand is not crappy. My old 390W psu is also CM and i have been using it for 3 years no probs whatsoever.
Reply to areszues92
From today:
http://www.tomshardware.com/forum/ [...] upply-blew
CM makes good cases. But they are still learning to build good PSU's.
Just because you bought one and got lucky does not mean they do not "build crappy power supplies".
Message edited by jsc on 11-11-2010 at 04:27:27 AM
Reply to jsc
It is possible you got lucky, or it is possible that CM brand labeled another manufacturers PSU for your 390W unit; CM is a tier 3 manufacturer. Seasonic, Corsair, enermax, XFX are all tier 1. As a tier 3 manufacturer, I wouldn't expect flawless operation, but I'd bet the protection circuitry is probably present, so when the unit does go, it is much less likely than some no-name brand of frying your computer, though I'd replace it anyway.
The buzzing could be (high pitched) a bad capacitor, (any pitch)a bad fan bearing, or (low pitched)winding vibrations. If it is intermitant, it's prob winding vibrations, which won't hurt anything as long as the coating doesn't wear off of the windings.
Reply to etk
The loud electrical buzzing sound seems to be gone after one night. But there is still a constant low pitched buzzing.
Reply to areszues92
People should stop riding the Corsair / Antec / Seasonic Bandwagon.
Yes, corsair is a great brand that has few faults, but all other brands have faults in at least 1 line of PSU - For Seasonic thats cost, Antec has Basiq power which is terrible, and XFX have PSU's that get 5-6 from Jonnyguru or hardwaresecrets.
Cooler Master have some good PSUs and some terrible PSUs.
e.g. Silent Pro Gold's are rocking out with 9~9.5 /10 from Hardware/Jonnyguru.
They'll also have some bad ones, but the only brand u can really buy w/o looking at the model except for the specs is corsair at least for now.
Other brands can have goodies too - and they'll often be cheaper
Reply to vibhas
The low powered Basiq's are kind of bad. The 500 watt Basiq is a pretty good unit.
http://www.hardwaresecrets.com/article/792
Reply to jsc
There are 1632 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Help Understaing Hardware Montior readings
By DJDeCiBeL, 1 hour ago:
 I agree with that assessment, and with the temps in that range, it's nothing to...
Best offers
Top experts
