Hi guys, sorry if i posted in the wrong section but there isn't a "General Help" section that i can find, so i'll post it here.
Ok so my 8 year old PC is acting up weird and not working properly. Everytime i turn it on, i get no screen displays at all, shows no information at all, not even the pre-bios information (the stuff you see straight after turning on your PC, such as the BIOS information, whether your hardrive status are OK etc).
Normally, straight after turning the PC on, the system will beep once and then show all the screen information. But mine doesn't do that anymore.
I unplugged everything and checked that they're all ok, plugged them back in and still couldn't get it to work. Sometimes it works, but very rarely.
There's nothing wrong with my ram or monitor or graphics card, they all work fine. I'm thinking maybe it's the CPU or motherboard coz they're quite old already. I'm using a ASUS P5GD1 motherboard, and a Pentium 4 3.4GHZ Northwood CPU.
I'm not sure whether it's the motherboard that's died or the CPU, I can't really tell and i did a lot of Google search on this and there doesn't seem to be a way to tell??
All i know is, all the fans work, so nothing is really dead......
Oh and i also replaced the CMOS battery with a new one but still it doesn't work.
