Hello everyone. Until a few days ago, my USB WiFi adapter worked perfectly on my motherboard's USB port (Asus M4a88TD-m/USB3) but lately it was working strangely and some days it wouldnt even work at all. I decided to format and start a new fresh Windows 7 Ultimate installation. The problem remains, when I plug the adapter to the Motherboard USB ports it works badly, detects the network but won't connect to it, and sometimes it won't even detect it.
BUT when i plug it to the front USB port (from a fan control bay) it works flawlessly. Problem is, my case has a 'door' and I can't shut it cause the adapter is in the way, which is annoying as hell.
I don't think the motherboard is the problem, cause I have a Razer Deathadder, a Logitech G110, an external WD 1TB drive and an Apple Dock connected to the Mobo's USB ports and they all work fine.
I would have no problem in buying a new WiFi adapter, but I don't want to waste money if the Motherboard results to be the real problem..
This is strange as hell... Does anyone know what it could be?
BTW: the adapter is a Realtek RTL8187B
Thank you.
Thank you.
