Where can I get a stand to turn my monitor vertical?
Ok, so as the thread title states, I am looking for a stand to turn my monitor vertical...actually, to be more accurate, I am looking for 3 monitor stands to let me turn my 3 23" monitors vertical, side by side.
I run 3 monitors with ati eyefinity and want to turn all three monitors vertical so instead of a really long screen I have a screen that is more squarish (I did the math and turning them vertical would result in a ratio between 16:10 and 16:9).
They almost certainly have to be single because a triple monitor stand wouldn't let me adjust the width so they are as close together as possible, no empty space between bezel, but if you find one that does and its reasonably priced i'll take it
So to keep this short, what I need is somewhere I can get 3 affordable single monitor stands (or one triple monitor stand) that lets me turn all monitors vertical and keep them right next to each other with no space between the bezel.
Thanks in advance all you awesome ppl!
1 answer Last reply
More about where stand turn monitor vertical
  1. Hey there,
    Try: http://www.widescreengamingforum.com/forum/viewtopic.php?f=64&t=18653
    Good luck.
    PS. Your monitors do support vertical placement, don't they?
Radeon Monitors ATI Graphics
