Closed
Question about PSU please help!!!!!!!!!!
hey guys i was thinking about upgrading my current rig, i already decided to upgrade my CPU to AMD Phenom II X4 955 95W on my M56S-S3 mobo, while still deciding on Graphics Card between HD 6870 and HD 6850
my current PSU is Cooler Master 460 RS-460-PCAR-A3 http://www.coolermaster.com/product.php?product_id=3686
i have question about the power supplies, i think my PSU is 460 watts, can it handle the 6870 or 6850 card plus the 955 CPU without problem? or will it bottleneck the PSU, what problem will it cause????
and if my current PSU is not enough to handle the upgrade, what PSU should i buy? I use my computer mainly for gaming and i live in Sydney, Australia so if u can find cheap good parts please post links. http://www.msy.com.au/Parts/PARTS.pdf this page got some PSU lists but i have no idea which one i should get, i don't have any idea about it so please leave recommendations and suggestions about the PSU. thx!!!!
13 answers Last reply
More about question help
  1. well, the general rule of buying a new PSU is buy the biggest you can afford...
    i dont know wat ur budget is, but id upgrade to about 720w. you might be able to use ur current PSU, but dont expect to overclock anytime soon!
  2. actually the only rule of buying a PSU is to buy the best quality PSU that will get the job done. more "power" on a PSU label does not equal a better PSU.
    here is a review of your extreme power 460 PSU
    Even though this power supply can’t deliver its labeled power, it isn’t a bad product for its price tag and targeted audience. Its real power is close to its labeled power (430 W) and its efficiency isn’t bad for a low-end product. Plus it has all its protections up and running, a thing sometimes hard to find on cheap power supplies.
    http://www.hardwaresecrets.com/article/Cooler-Master-eXtreme-Power-Plus-460-W-RS-460-PMSR-A3-Power-Supply-Review/550/10
    I would suggest a quality PSU with 30a on its 12v rail (typically a 450w+ unit)from corsair, silverstone, enermax, seasonic, or antec. xigmatic and OCZ also offer budget unit that can get the job done but drop a bit in quality from the units mentioned. You will find any of these units superior to some non-name budget 720w unit.
    luckily both the 6850 & 6870 are very power efficient cards. your current PSU could probably power either one but I would look toward a future PSU upgrade anyways.
    Wrong one ct
    http://www.hardwaresecrets.com/article/Cooler-Master-Elite-Power-460-W-Power-Supply-Review/1005/1
  4. the op linked to the eXtreme Power Plus 460W
    (RS-460-PCAR-A3 / RS-460-PCAP-A3)
    i linked my review to the
    Cooler Master eXtreme Power Plus 460 W (RS-460-PMSR-A3)
    your link is to
    Elite Power 460 W (RS-460-PSAR-J3)
    ...how many junk PSU can CM make under different model #?
    your link is to
    ...how many junk PSU can CM make under different labels?
    It's just like the little Thermaltake 430, give it another model number and keep on selling :pfff:
  6. lovely, nothing like screwing the public
  7. this is more confusing, according to this thread here
    http://www.tomshardware.com/forum/279391-28-power-requirements-specs-popular-graphic-cards-guide
    the recommended power supply for gtx460 is 450 watt and the gtx470 550 watt
    whereas the requirement for the HD6000 series card is 500 watt, so the 6850 actually requires more power than the gtx460???
    also are power consumption and power requirement two different things??? cos their values are always way off.
    and can someone list the recommended PSU power supply for the 6870+phenom 955 and 6850+phenom 955
  8. ati/nvidia post requirements/recommendations (same thing) to cover themselves for poor power supplies. they are simply making guess so that low quality units are covered. the chart above shows you want a PV with an Over clocked i7 CPU and 6850, 6870, etc., will use in a max stress test. as i stated above, a quality 450-500w will do the job.
  9. oh, that makes sense
    so it means my current 460w PSU is more than enough to handle the HD6870 (306w) and the Phenom II X4 955 (95w)?????
  10. i think you should read the review linked by delluser
  11. just read the review, says it can only handle up to 420w
    but with HD6870 + Phenom II X4 955, the consumption is 401
    it means the PSU still can handle those parts right???
    or will it be cutting it too close, what will happen if its near the peak supply?
  12. Quote:
    Don't...
    * Post in ALL CAPS or use excessive punctuation!!!
    * Share personal information, like your email address. Identify theft is real.
    * Bump posts, claim "first!"
    * Hijack a topic. Stick to the original conversation.
    * Ask for help pirating, cracking passwords, or bypassing copyright protection
    Source.
Power Supplies Components
