Sign-in / Sign-up
Need your help
  • Graphics Cards
  • Cooling
  • Intel i7
  • Power Supplies
  • Motherboards
  • Processors
  • Graphics
Last response: in Graphics Cards
July 20, 2010 10:00:12 PM
can GTX460 work on power supply 460 watt cooler master
i have
Processor i7 930
Mother board X58 A UD3R
More about : question
July 20, 2010 10:03:05 PM
It should work on a 460W psu, Ive had 5870's running on 200W psu's before.. So getting a 460 to run on a 460W should be fine
m
l
a c 236 U Graphics card
a c 165 ) Power supply
a b V Motherboard
July 20, 2010 10:05:24 PM
if its the extreme power plus 460, you are really pushing it
if its the Master Elite Power 460, you are really really pushing
both are really 400w units
m
l
a b V Motherboard
July 20, 2010 10:06:00 PM
....................................................... :pfff:
m
l
July 20, 2010 10:15:24 PM
ok what is the best VGA card do you recommend for that PSU
m
l
a b V Motherboard
July 20, 2010 10:21:37 PM
the ATI 5770
m
l
July 20, 2010 10:22:54 PM
It is possible to run the 5870 on a 200W psu, just not the best ideas... tried it with 2 5870's one was Sapphire Vapour-x other was just a standard xfx 5870, both of them ran fine for general purpose pc usage.. when gaming got involved the Sapphire card couldnt run, the xfx ran fine though which was kinda supprising since it says 500 - 600W recomneded Power. so you can run a card on less then recomended and it work fine but like i said, not the best of ideas lol was a fun test to do though
m
l
