Verify that you have connected the front panel leads to the right places on the motherboard.
If the led leads are plugged into the power switch for example, you will get strange results.
You should be able to power up the motherboard with only the power switch. Add the others one at a time to isolate the problem. Possibly a front panel lead is miswired or mislabeled.
