Closed Solved
Will this Power supply handle this graphics card?
OCZ Fatal1ty OCZ550FTY 550W ATX12V v2.2 / EPS12V SLI Ready 80 PLUS Certified Modular Active PFC Power Supply
will it hold a GTX260 or GTX460? Im simply talkin about connectors. I know the 260 needs two pci-e connectors. This power supply says it has one 6 point connector and one 6+2point connector. Is that still okay? This Power supply is on sale for pretty damn cheap today, and I want to go ahead and get it if its compatible
12 answers Last reply Best Answer
More about will power supply handle graphics card
  1. It should, how many amps on the 12v. Also how cheap is it and where from? You can get a Seasonic that will run those cards easily for around 59.00, and will be superior to the OCZ
  2. 58.99 after 6.00 promo code (its on sale today for black november.) and it has a $20 mail in rebate. one other thing worries me, It has a 30 return policy. well, what if i dont finish buying all the parts and building the computer by then? You think I should go ahead and get it. It seems like it should suffice. Cant afford to waste money, but this just seems like a sweet deal.
    BTW, i bought that memory you told me about. $50bucks after mail in rebate. Nice deal, thanks. Actually is the first part I bought. Now I want to move forward with this. is it a good idea for that price? and given the dilemma about the warranty?
  3. oh, its at newegg. so it comes out to 38 bucks after promo and MIR
  4. NP glad i could help
    Seasonic is one of the best if not the best power supply manufacturers out there. OCZ is decent, but can't hold a candle to Seasonic, read some reviews if you don't believe me. For 59.00 you really can't beat it IMO
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817151094
  5. yeah I looked at that one. I really only wanted to spend $50 bucks on one. I would buy that one you just showed me, but its $70 after shipping. Have you found it anywhere else for cheaper? Im willing to spend $60 I think. (Im very low on funds, every dollar counts)
  6. For 38 it might be worth it, that's real cheap
  7. Looks like alot of people say the MIR is practically impossible to get. I dont know, Id hate to buy something and it be DOA, but I not hook it up for 30 days and then I cant return it. This is stressful. LoL. So you dont know of a better power supply for $60 after shipping? Something you feel wont be DOA..
  8. Best answer
    the OCZ PSU is up to task for either nvidia card. here is a review of it, its not great but it will work and you can do worse.
    http://www.anandtech.com/show/3985/three-550w-psus-for-different-prices/14
  9. Honestly I haven't found a better power supply for the money than that seasonic in the brief search I just did. I'm not saying there isn't a better value out there, but it might be tough to find, or you'll just have to be patient and wait until something presents it's self. maybe look at open box sales, see if something good shows up.
    this is best PSU on newegg under $53 shipped. seasonic made, it peaks at 490w and has 30a on its 12v. you will need to use adapters since it only has one power cable.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139008
    bit tech uses it in their budget build for the GTX 460 1GB
    http://www.bit-tech.net/hardware/buyers-guide/2010/09/07/pc-hardware-buyer-s-guide-september-2010/2
  11. Best answer selected by NickCapolupo.
  12. This topic has been closed by Mousemonkey
Power Supplies Graphics Cards Components Product
