Yes No
Ads
A new power supply
Forum CPU & Components : Power Supplies, Cases & Mods A new power supply
I am going to need a new power supply for a graphics card, and I need to know if it will be safe.
I have an HP Pavilion a6512p desktop. I'm going to be getting a 450 watt power supply if its safe, so I need to know what the limits are.
Thanks
Reply to snipuh
What graphics card are you getting and what 450W PSU are you considering? Not all power supplies are created equal so links to the GPU and the PSUs you are planning to get would be helpful, as would a budget for the PSU.
Reply to hunter315
Depending on your answers to hunter315 (what graphics card? budget?), I'd probably recommend this:
http://www.newegg.com/Product/Prod [...] 6817139017
or this:
http://www.newegg.com/Product/Prod [...] 6817151094
Reply to Twoboxer
Radeon 5570 and the cheapest power supply i can get.
would this one work?
I need a 450W one according to newegg for that card I think
http://www.newegg.com/Product/Prod [...] 6817170014
Reply to snipuh
LOGISYS PSU's are junk.
Reply to jsc
BAD! VERY BAD!
never ever ever ever go for the cheapest unit you can get. I would go for either the Corsair 430CX that twoboxer linked to or the antec EA380D, both of them would have plenty of power for that system and arent likely to explode spectacularly.
http://www.newegg.com/Product/Prod [...] Tpk=ea380d
Reply to hunter315
I WILL get the cheapest power supply that will work, I'm low budget, what I'm asking for is a cheap power supply that will work with my computer that is around 450W. I'm not one of those people who has lots of money to dump into their computer, all i care about is getting a power supply that works and is cheap. I'm not going to upgrade again.
Reply to snipuh
The units we are suggesting arent very expensive, $35 after MIR isnt much for a power supply, especially a decent one that isnt going to blow up. If you get that logisys PSU, i doubt your system will survive another year. A super cheap PSU is never a good value, especially one that cheap that shouldnt be more than a 300W unit, its a fire hazard and can kill your system if it goes.
Message edited by hunter315 on 11-14-2010 at 01:24:12 AM
Reply to hunter315
"Went out in a hail of sparks after 3 months! I hope it didn't take anything with it."
First review
http://www.newegg.com/Product/Prod [...] 63938&SID=
:lol: :lol: :lol:
Reply to delluser1
but will those other PSUs fry the motherboard? thats what i was told could happen if I got a PSU that was too strong for the computer.
Message quoted 1 times
Message edited by snipuh on 11-14-2010 at 01:30:20 AM
Reply to snipuh
snipuh wrote :
but will those other PSUs fry the motherboard? that what i was told could happen if I got a PSU that was too strong for the computer.
That's a myth by the oem's to get you to buy a new machine.
Reply to delluser1
You can put a 1200W unit into a tiny office PC, nothing bad will happen.
PSUs output a constant voltage, the components draw as much power as they need from the PSU, just because you put a 1200W PSU in doesnt mean that the system will be using 1200W, it justs means it would be able to, the system only draws as much power as it needs exactly at that time.
Reply to hunter315
There is no such thing as too much power(within reason, ^1200w example^) but you can have too little or poor power. Just because its cheap is not a good way to go as others are trying to explain, it is best to spend the extra couple of dollors than to have your PSU or entire PC go up in smoke and flames, maybe even harming you or damaging your home. Cheap PSU's normally do not meet there advertised rated power nor do they put out clean power signals like the models that were suggested to you because they use cheap/inferior parts, and both of these factors can affect the longevity of your PC's parts and in turn cost you much more in the long run.
You may want to check out this article Tom's published just yesterday:Who's Who In Power Supplies: Brands, Labels, And OEMs
Just reading the reviews on the LOGISYS PSU should make anyone think twice about buying it.
Message edited by thechief73 on 11-14-2010 at 01:46:22 AM
------------------------------ Must Read: PSU Info - PC Tools - Guides
Folding@Home: THGC Needs You! -Team 40051
Free Half-Life 2 DM for ATI owners
Reply to thechief73
This is the cheapest psu we here will recommend for you:
Anything of lesser QUALITY could harm your PC, fail prematurely, or fail spectacularly.
If you want to buy something cheaper, you are quite on your own.
Reply to Twoboxer
I have to agree with the suggestions hunter315 and Twoboxer gave you, really if you want to any cheaper, your going to get less quality parts and are taking quite a risk, you have been warned, cant say we didnt try.
Reply to thechief73
The Corsair Builder series is a step backwards. Their old CX line was, but the new ones aren't even 80+ certified. In that range, about the best you'll do is the 380W Antec Earthwatts, which is 80+ bronze and runs very cool and quiet.
Edit: and, as they've said, the PSU is NOT the place to go cheap. You risk your system with a chokemax brand like Logisys. At a minimum, look for full range active PFC (no little voltage switch) and 80+ certification.
Message edited by jtt283 on 11-15-2010 at 03:48:20 AM
Reply to jtt283
At $25, this is more than enough power for a 5570.
http://www.newegg.com/Product/Prod [...] 6817371033
Get a good PSU, the logitech one is probably as good as whatever you have now.
Reply to duk3
Buying a crap psu is like buying a used condom,it will work but its not exactly a good idea
Reply to obsidian86
^+1 hahaha, nuff said bro. XD
------------------------------ http://valid.canardpc.com/cache/banner/1432154.png
Reply to drexeus
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > A new power supply
There are 1605 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Help Understaing Hardware Montior readings
By DJDeCiBeL, 1 hour ago:
 I agree with that assessment, and with the temps in that range, it's nothing to...
Best offers
Top experts
