Ok, my power supply came stock with this case:
http://www.newegg.com/Product/Prod [...] -_-Product
if you zoom in on the picture, you can see the specifications, I THINK it has the 12v rail on 15 amps, cause it says something like 12v- 15.0 a (YEL) which seem to be for yellow? i dont know.
The thing is, I've narrowed down my options to this 3 cards (according to availability and price):
The Gigabyte 4670 1gb ddr3 at $115
The Gigabyte 5670 1gb ddr5 at $155
The Zotac 240 1gb 512 ddr5 at $122
If I compare it to the prices at newegg, the Zotac is the one that stays the closest to it's newegg price.
The problem is, with both the 4670 and the 5670 the min. requirements are 400w, I've seen through the forums that ATI inflates those requirements, and that a "decent 300w psu" will easily run it, so, is mine decent enough?
On the other hand, the Zotac 240 asks for a 300w supply but a 12v on 18 or 21 amps... dammit I forgot... the case said the specification, and mine seems to have a 15 amp. 12v rail.
So, now that you have all the info... what should i do
