Here's the error,....Health is 0% Performance is 100%
Failure Predicted - Attribute: 1 Raw Read Error Rate, Errors occurred while reading raw data from a disk. Indicate problem with the disk surface or the read/write heads.
There are 18 weak sectors found on the disk surface. They may be remapped any time in the later use of the disk.
Replace hard disk immediately.
It is recommended to backup immediately to prevent data loss.
