Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > Problem replacing 8800gt with 460gtx
Forum Graphics & Displays : Graphics Cards Problem replacing 8800gt with 460gtx
As the title suggests I have a problem.
Replaced a BFG 8800gt with a palit 460gtx to allow for upcoming direct X 11 games.
Now have far worse performance, in all games low fps and even jerky in the menus.
Went into safe mode and cleaned out the drivers and re-installed, no improvement.
Any suggestions please.
Reply to Doomed_UK
CPU? PSU?
full system specs if we are to help.
did you run driver sweeper after removing the old drivers? and are you using the latest video drivers?
------------------------------ CM 690 II Advanced|ASUS P8z68-v GEN 3|i5 2500k @ 4.8Ghz (Wet)|8gb Ripjaws X| GTX 680 |Crucial M4 128gb SSD|xfx 650w
Reply to welshmousepk
Please list the rest of your system specifications, including operating system.
Reply to Herr_Koos
Silverstone 600w psu
4gb ram, possibly elixir (2x2gb)
intel motherboard, dont know which one (not a top of the range one)
Intel Core 2 Duo E8500, S775, Wolfdale 45nm, 3.16 GHz
win 7 (upgrade over win xp, not clean install)
Reply to Doomed_UK
welshmousepk wrote :
CPU? PSU?
yes, ran driver sweeper and have tried latest drivers.
Reply to Doomed_UK
- 0 +
power is running to both connectors? all the adapters (if used) are secure?
Reply to ct1615
both adapters are plugged in - I will unplug and plug back in later to double check.
No adapters needed/used on the silverstone
Reply to Doomed_UK
If the problem still appear, you need to return your graphic card from where you buy it
mybe your card have a problem.
Reply to dinkle85
You can't upgrade XP to 7, so I'm not quite sure how you managed that. What steps did you follow when doing this?
Reply to Herr_Koos
I bought an win 7 upgade only disc
Reply to Doomed_UK
I'm suspecting that and/or driver issue and the driver issue may have roots in the first bit.
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
OK, sort of solved.
I took the 460 and put it in another of my machines (i7 920, 6GB, win 7 pro) and it works fine.
The 260 I took out I put back in the other machine and it works fine......
Dont know why but both machines are happy.
I really wanted the 460 in the other machine as one of my boys plays games alot on it, but I cant be bothered to fathom out whats going on.
Thanks for all your input.
Reply to Doomed_UK
i have the same problem , low fps , jerky in games its bad , ive tried reinstalling drivers but not worked its upsetting as i was getting better performance with my 9800gt, my system specs:
asus ENGTX460 TOP 768MB
ASRock G31M-S Mobo
3gb ddr2 800 Geil
creative soundblaster fatality pro
750w powercool 80+ psu
360gb sata hdd
core2quad q8300 2.5ghz {no OC}
This problem is doing my head in i just want right , please help if you can:)
Reply to Anonymous
I didn't think there was anyway to upgrade completely over Vista and go from XP to Win7..
All I ever have known was a clean install from XP and that's it.
Upgrades only from Vista and lesser versions of Win7 use the anytime upgrade..
------------------------------ A+, Net+, MCDST, DSCE (Dell)
Reply to malmental
install a clean windows 7 edition,and reinstall games and drivers and see magic,same happened to me when i upgraded from 9400gt to hd 3870.
Reply to mrjericho1991
There are 1617 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
I need a new video card - Help?
By Pinhedd, 1 hour ago:
6670 1GB hands down. The 6570 is less powerful and has inferior GDDR3 RAM which is vastly...
Best offers
Top experts
