Heatsink fan- 3pin vs 4pin problem
I Bought an http://www.newegg.com/Product/Product.aspx?Item=N82E168... mobo and it is not working with my new CPU http://www.newegg.com/Product/Product.aspx?Item=N82E168... my CPU acts as if it is not getting any voltage...it does not get warm...I checked the voltage with a multimeter coming out of the PSU to the CPU connector and it measured a CORRECT 12volts...so I ordered a replacement CPU to see if it was the CPU...plugged in the new CPU same problem...so my last thought is this..
The Heatsink fan is a 3 pin for an old AMD athlon 64...it fita like a glove but the mobo has a 4 pin connector for the CPU can...if my board has a safety feature that will not give the CPU power if all 4 pins are not connected...because the board otherwise thinks there is not a HSF on it...anyone know if this is true with my MOBO...ASUS is not currently open so here i am going to the always helpful tomshardware forums :)
any answers are appreciated :)  thank you! - David
Motherboard Expert
CPUs Expert
Can't comment on AMD, but on Intel you can definitely use a 3 wire fan on a 4 wire header and it will work fine - I'm doing that right now because I'm running a Noctua cooler with a three wire fan instead of the 4 wire Intel stock cooler.
I don't think that's your problem - I think you have a motherboard problem.
Ask the community
