Solved
First build - help/suggestions?
This would be my first attempt at a build. I went to cyberpower pc to get an idea of what would actually go into a computer and what I might want to look for. This computer will be used for both gaming and other matters, so should be able to run Photoshop CS, Word, etc, as well as easily run MMOs like D&D Online, Sims 3, and various CD-related games (Age of Empires, for example). And music, yes. We do like our music. ;)
Here's the build I have thus far. I'll be buying mostly from NewEgg whenever possible. I do have a budget, however.
Case: RAIDMAX Typhoon ATX-312WS Black SECC ATX Mid Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811156244
Processor: AMD Phenom™II X4 965 Black Edition Quad-Core CPU w/ HyperTransport Technology (125W)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
CPU Fan: CoolerMaster Hyper TX3 Gaming CPU Cooling Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103064 (I assume the case has its own default fans?)
Mobo: MSI 770-G45 AM3 770 Chipset CrossFireX Support DDR3 Socket AM3 ATX Mainboard w/ 7.1 HD Audio, GbLAN, USB2.0, SATA-II, RAID, 2 Gen2 PCIe, 1 PCIe X1, & 3 PCI
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130250
Mem: CORSAIR DOMINATOR 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMP4GX3M2B1600C8
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145303
HDD: 1.5TB SATA-II 3.0Gb/s 32MB Cache 7200RPM HDD
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148337
PSU: CORSAIR CMPSU-850TX 850W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139009
Video: SAPPHIRE 100283L Radeon HD 5770 (Juniper XT) 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102858
Sound: Creative Labs SB Audigy SE
http://us.store.creative.com/Sound-Blaster-Audigy-SE/M/B000LP0R3E.htm
Optical: MSI 18X DVD-ROM 48X CD-ROM IDE DVD-ROM Drive Model DH-18D4P
http://www.newegg.com/Product/Product.aspx?Item=N82E16827100067
OS: Windows 7
Network: Onboard Gigabit LAN Network
RAID: no
Monitor: Have one
Speakers: can get them
Anything else I might be missing? :)
-Shadeling
26 answers Last reply Best Answer
More about first build help suggestions
  1. There is not reason not to get a newer 870, 880 or 890 chipset motherboard with USB3 and SATA 6GB. The prices are so close and USB3 will likely be useful very soon.
  2. $664AR for tower?
    Would this one be better, then?
    MSI 890GXM-G65 AM3 AMD 890GX HDMI SATA 6Gb/s USB 3.0 Micro ATX AMD Motherboard
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813130269R
  4. I would switch the RAM to this:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231279&cm_re=g_skill_4gb_ddr3_1600-_-20-231-279-_-Product
    It has better timings for identical price.
    Corsair are quality brand but overpriced. G Skill are just as good and my preffered choice over corsair.
    Is only a small modification, but you get slightly better performance for same price.
    Comes down to preference at the end of the day.
  5. Just realised you are doing an AMD build and not intel, scratch my last post.
    I wouldnt buy open box. My own experience is that ASUS and Gigabyte are more reliable then MSI.
    Ah, a second one for ASUS. I'll have to look into that.
    As for the case: is it large enough, or should I look at a better one?
    Are they compatible with a Phenom II X4?
  9. I like that ASUS motherboard just fine.
    RAM compatibility is with the motherboard, not CPU. Basically all DDR3 RAM is compatible with all AM3 motherboards, if the RAMs voltage rating is 1.65V or less.
    The case says "ATX" so it will handle any ATX size motherboard. The only possible issue with an ATX case is if you buy a large graphics card. By large I mean longer than the 9.6 inches wide an ATX motherboard is. With a 5770 or 460 there are no worries. I do see problems with that case, though.
    One problem with that case is the width is too narrow to fit good 120MM tower coolers. You want an 8.1 inch wide case to hold a good 120mm tower cooler like the coolermaster hyper 212 plus, xigmatec balder or dark knight, sunbeam core contact freezer or Scythe mugen 2 (scmg-2100).
    Another problem is that the fan is place above the CPU and not the graphics card. It is and old design from when the CPU coolers aligned the fan horizontally over the CPU and graphics cards were not the primary heat generator.
    The last problem is that while it has a nice big 120mm intake on the front and an 80mm intake on the side, there is only one 80mm exhaust fan to pump the hot air out. If it had a top vent with another 120mm exhaust fan it would be great, but as it is I worry about possible problems venting the hot air out.
  10. That motherboard looks fine to me. I've never done an AMD build myself, so I'm not so hot on AMD motherboards, but it looks fine to me. Someone feel free to suggest a better board for his needs if there is one.
    But I would definately stick with an ASUS board, with Gigabyte a great alternative.
    This is a great case, but pricier:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197&cm_re=haf_922-_-11-119-197-_-Product
    You won't go wrong with this case, heaps of space and great ventilation.
    Would an 8.0 inch wide case work, or does it need to be wider than that?
    And is this case old design or new?
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811156242
  12. I'm not too sure on whether 8.0 is wide enough, but here's a cheaper option than the one I posted before that are over 8.1 wide:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811112236
    and a review on it, seems pretty good for the price:
    http://benchmarkreviews.com/index.php?option=com_content&task=view&id=449&Itemid=61&limit=1&limitstart=5
    what is your budget though?
    My current budget is between $900-1000. If I can get a build in that range that would let me upgrade a couple of things fairly easily later on, that'd work as well. I'm having to save up for something else at the same time, though, or I'd probably up that by at least another $200-500. :/
  14. dndhatcher said:
    I don't believe this is the Illusion, but it IS an Antec 300.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
    Would it work as well? It seems to have the low side vent and the width needed for a 120mm fan.
  15. Ok, well I just did a calculation of the items you have listed:
    If you use everything in your OP with the following modifications:
    1. Swap the case for the HAF 922 I suggested
    2. Get rid of the CPU fan (you don't need it).
    3. Swap the mobo for the ASUS one you found.
    4. Switch the RAM to the one I suggested.
    Then it comes in at $875.90.
    So you still have a little left to spare with that set-up.
    Its the same case without the front 2 intake fans installed.
    Right now the black is on sale so its a better deal. If you are not pressed for time, the illusion will probably go on sale for $60 and free shipping, or you might find it somewhere else on sale right now. If you arent putting lots of HDDs or hot graphics cards in, the front fans are not needed.
    The one HDD that I have listed should be enough for the gaming AND what all else I want to do with it? Because I do have an external HD that I got as a gift to store a lot of other stuff if there's a problem (a Seagate Freeagent 320GB). I just tend to prefer my stuff where I can access it and manipulate it and save it all in the same place.
    Also: would rikishi19's build (with what he just offered as replacements to my original one) work just fine? I ask because I like accord. ;)
    That build would work much better and do what I need it to, then? And I can upgrade it later if necessary (when necessary) without having to buy what makes up a whole new computer all at once? (I have an eMachine at the moment, store-bought, and it's about 6-7 years old now - and having restart probs - but in the end it's just not up to snuff when it comes to gaming these days).
  19. Best answer
    Now that I have experienced the joy of having dust filters, I dont think I could buy a HAF 922 since it doesnt have them. Other than that is is one of the best and largest cases for the price and many people praise them.
    You need some CPU fan, though your CPU may come with a barely acceptable one already. You need to check your CPU to see if it does or not.
    The Kingwin 1264 is only $25 and is a decent 120mm cooler you could get instead.
    Ripjaws just jumped $20 in price.
    Gskills Eco series is lower voltage and doesnt have the "jaws" heat spreaders that can sometimes get in the way of the CPU heatsink.
    http://www.newegg.com/Product/Product.aspx?Item=N82E1682023132
  20. Final build:
    Memory: G. Skill ECO series:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231321
    CPU Fan: Cooler Master Hyper 212 Plus
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
    Mobo: ASUS 870
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131651
    Case: Cooler Master HAF 922
    Processor: AMD Phenom IIX4 965 (125w)
    HDD: Seagate Barracuda 7200.11
    PSU: Corsair CMPSU-850TX 850W
    Video Card: Sapphire Radeon HD 5770
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814102873
    Optical Drive: MSI 18X/48X DVD-ROM/CD-ROM
    Sound card: Sound Blaster Audigy SE
    OS: Windows 7 (64-bit)
    Speakers, Monitor, mouse, keyboard - already have them
    So, last call: anything with this updated build need changing? The optical drive? Video Card?
    I've posted a "final" build now. Updated and such. :) Feel free to have a go at it.
    Well, I did an updated, "final" type of build and listed it, so feel free to have a look if you desire. :)
  23. Best answer selected by shadeling.
Homebuilt Systems Product
