It looks like it should support 2GB of RAM, BUT, this MUST be 1GB sticks. It also takes DDR memory (probably DDR 333). There isn't *much* information around however I gathered enough to conclude that you should be good to go with this.^
If you can figure out what type of memory it uses we may be able to verify. Download System Information Wizard (http://www.gtopala.com/siw-download.html) and download the freeware, stand-alone zip and run the .exe. Under the hardware option, select memory. Then look for the "Memory Type" under the current memory. Also, under the "Motherboard" option, it should have a "Memory Summary" and then a "Memory Supported" option. That will tell you everything you need.
