Need help
July 24, 2010 10:59:15 PM
I just installed my ati 4350 an my onboard sound stop working for everything what do i do. or can I just buy a new sound card <would that wok.
More about : question
July 24, 2010 11:20:31 PM
Did you remove your old card's drivers and install the latest Catalyst ones?
Also try reinstalling your audio drivers.
m
l
July 25, 2010 9:56:02 PM
well if i get a new sound card wil theat work cuase my old onboard sound card wasnt that great a i wanted a new one.
m
l
July 25, 2010 10:24:16 PM
The 4350 has probably been set as the default sound card which is why your onboard no longer works.
m
l
July 26, 2010 2:38:15 AM
how would i fix it i already disabled the 4350 sound card what should i do then after that.
m
l
July 26, 2010 3:18:38 AM
You might need to go into the windows control panel and set a default sound device.
m
l
