I am using a desktop computer with the following spec:
MB: Asrock 939N (?) I couldn't recall the proper name.
CPU: 2.0 GHz Athlon64 X2
HD: RAID 0
RAM: 2GB RAM DDR1
GFX: ATI X1600 EAX
PS: Enermax 350W
This computer is 4 years old, uses only 120W at 100% peak and I am thinking of upgrading the GFX because the computer is having trouble with decent framerate. I am thinking of only changing the GFX, but other old components would be bottlenecks. I am wondering how bad will it get? For instance, if I replace X1600 with 5850, I won't get 100% performance. The question is how severe will the bottleneck be? Will I only get half the performance of 5850 or even worse? Does it even worth it to upgrade?
(To be honest, I wanna play Crysis on High setting)
HD: RAID 0
RAM: 2GB RAM DDR1
GFX: ATI X1600 EAX
PS: Enermax 350W
