Hello,
I have a Dell 0T568R motherboard, it came standard with a 350W PSU. I contacted Dell regarding a PSU upgrade and they told me a PSU upgrade was not recommended.
"If you want to Upgrade the power supply , you Have to check with the system chasis design and it also should be compatible with the system board requirements."
The PSU bay is huge and will fit, I would think, any new PSU unit.
My question is, has anyone upgraded this MB to a higher PSU or purchased it with a higher PSU. Or if anyone just knows if a higher PSU will not hurt my computer. I would like to upgrade the PSU in order to upgrade my graphics card.
