I have a bit of a mystery on my hands, yesterday I put together my new PC, it posts just fine as long as I don't connect the 200mm fan at the top of the Antec 600 case. I'm using a Antec Earthworks 750w power supply, I can run the two 120mm front fans as well as the rear 120mm fan without issue(all molex) but when I hook up the 200m even with the remaining fans disconnected it just clicks on for less then a second and thats it.
I pulled everything out and went through breadboarding as mentioned in the troubleshooting threads and everything worked fine. I even went so far as to use one of the additional modular cables and give the 200mm fan its own connection with nothing else, still nothing.
My last step was hooking up the fan to my old dell PC and it ran okay.
Where do I go from here? Am I looking at a bad PSU?
