Solved
Dual Input display in a single monitor
  • Radeon
  • Monitors
  • Graphics
  • Displays
July 25, 2010 4:42:17 PM
Is it possible for me to have two display inputs on a single monitor?
I have an external TV tuner card connected to the DVI port on my monitor & the CPU connected on the VGA port. Is it possible for me to have both the displays on my single monitor side-by-side or like PIP?
Acer 23" h235hbmid HD Monitor [VGA, HDMI, DVI]
Onboard Graphics - ATI Radeon 4250
More about : dual input display single monitor
Best solution
a b C Monitor
July 25, 2010 8:57:13 PM
I don't think a feature such as Picture In Picture exists currently with multiple inputs as you have suggested. (though it would be very cool if it did)
You can plug in more than one video source into your monitor however you can only view one of those items at any given time, you would have to change input sources.
For example I have a Westinghouse w22v2 that has 4 different inputs:
Component which my Xbox is plugged into
Composite which a VCR or my old GameCube could be plugged into
VGA for computer A
DVI for computer B or A which I could run in either Extended, Clone or Single Large Display (Eyefinity) (the last 2 being somewhat pointless)
August 7, 2010 11:19:32 AM
Best answer selected by deppfx.
m
l
