Good Morning -
I built my first pc about a year and a half ago with no issues whatsoever. Now all of the sudden my computer keeps randomly rebooting. Sometimes I'll be using windows for a half hour or so with no issues until a reboot, and other times it will get itself into a cycle where it will reboot, not even finish loading the bios, and then reboot again.
I took the computer to a PC place where they did a diagnostic. They "claimed" they swapped the parts and it was either the MOBO or the CPU. Figuring the failure rate on the MOBO was much higher than the CPU I RMA'd the MOBO. After weeks of waiting and finally slapping it all back together I am seeing the same issue.
I dont think its a heat issue as I installed speedfan and temps seem to be very stable and operated usually between 50-60c when under load for all areas. I am obviously sick of the problem and dont know what to do. I could RMA the CPU but if thats not the issue its another 2 weeks and no progress. Could it be a bad power supply? I wonder if the PC place (pretty reputable within the milwaukee area) did a lazy job of actually trying to solve the problem. I dont think its a windows issue as it will sometimes reboot before even loading vista
Any help is greatly appreciated. Thanks in advance for all replys
ENCORE ENLWI-N PCI 2.3 Wireless Adapter
LG 22X DVD±R DVD Burner Black SATA Model GH22NS30 - OEM
Arctic Silver Ceramique Thermal Compound - OEM
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA
G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666)
ASUS P6T LGA 1366 Intel X58 ATX Intel Motherboard
SAPPHIRE 100259-1GL Radeon HD 4870 1GB 256-bit GDDR5 PCI
Microsoft Windows Vista Home Premium SP1 64-bit for System Builders -
Intel Core i7-920 Bloomfield 2.66GHz LGA 1366 130W Quad-Core
PC Power and Cooling S75CF 750W EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Active PFC Power Supply
