this is the build that i have come up with. it is mainly for gaming and internet browsing. i have a laptop where i can do my work and all that good stuff.
processor-amd phenom x2 555-90.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16819103846
motherboard- asus m4a785td-v evo-99.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16813131398
it says the motherboard is a crossfire hybrid because it has integrated graphics. i plan on getting a 5770 eventually. my question is that if i were to get 2 5770s and disable the integrated could i use crossfire?
ram- 4gb g skill- 80.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231253
case-antec three hundred illusion- 69.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
power supply- antec earthwatts 650 watts- 79.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16817371015
the case and power supply come in a combo for 129.99 plus a 15 dollar rebate so around $115
hdd- wester digital 500gb-54.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16822136497
optical drive- lite on dvd writer w/ lightscribe- 19.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16827106333
os- windows 7 64 bit 99.99- http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754
total comes out to be around 576 dollars plus i have the mail and rebate.
