Closed Solved
Building case from scrach, need grounding advice
Hi
Not sure if this is the right category for this question...
Or if this is a stupid question or not...
Im thinking about building a case out of wood. I googled the subject and I havent found anywhere that says the motherboard HAS to be grounded and on a metal motherboard tray. I was just going to drill holes and screw the standoffs into the wood and slap the mobo on that way. I figured it would be grounded by the psu.
BUT every wooden case mod I have looked at online seems to be using another cases mobo tray or a DIY mobo tray from somewhere. Is that really necessary? Or can I just attach all the components to the wood itself without problems?
Thanks in advance for any advice on this!
7 answers Last reply Best Answer
More about building case scrach grounding advice
  1. You could just run an earthing cable from a mobo mounting hole to the psu casing only risk is if the psu went, it could send a current down to the mobo, but that could happen via the power cable. I wouldn't worry, give it a good test using old parts that you wouldn't miss if things go wrong.
  2. in my shoebox-pc, when i made it people were telling me i needed ground-well i guess not, it still works lol. dont bother with grounding the case.
  3. Best answer
    no grounding necessary. Go ahead and build it as you like. The PSU is grounded anyways via it's power cable.
    The reason cases are built out of metal is because the case itself can take some of the heat from inside and radiate it, hence helping cooling. Also, when serviced, if someone grounds himself to the case, reduces the odds of causing an electrical charge and zapping the mobo. Other than that, no issues.
  4. the metal cases also have to with fcc regulation, emi, and stuff. but it shouldnt really be a problem unless you have it right next to your radio or whatever
  5. Awesome, good to hear! Thank you all for the info!
  6. Best answer selected by tacoma08.
  7. This topic has been closed by Maziar
Power Supplies Cases Do It Yourself Motherboards Components
