Hi all,
This is the first time I post on this forum and I hope you can help me with a qualified answer to my question.
---------------------------SPECS--------------------------------------------
I have a rig with 8 SATA hard drives, four of which is attached in a hot swap array for storage. The four remaining disks are arranged as follows.
1x Windows 7 disk
1x Linux boot and /
1x /var
1x /home
^^ This is not really that important info but it helps mystify the occurrence of my problem.
The rig runs 24/7 and this has not proven to be a problem.
---------------------------WATCH OUT RANT AHEAD, goto next section to bypass--------------------
This morning my girlfriend was vacuuming and running the laundry on the same time. While this has not shown to be a problem before a fuse blew. The RCCB did its job and disconnected the main. She called med at work and I guided her through the process of changing the fuses and getting the power back on. Anyways I come home and I turn on my machine and it cant load the OS!
---------------------------THE PROBLEM-----------------------------------------------------------------
When turning on the rig I can hear 'beeping' noises from two of the system disks. This is actually not the disk beeping but the sound of the actuator arm moving in a pattern that emits whats seems to be a beeping sound.
I have read everything I could get my hands on regarding recovering from hard drive failure and it is prominent that it is a physical problem. The reason as I understand, is because the disk cant find or read the system area or cant find or read cylinder boundaries.
Recovery can 'possibly' be done by getting professional help which is too expensive for my budget.
My question is, how can a power cut create the same failure on two different disks at the same time?
1x Windows 7 disk
1x Linux boot and /
1x /var
1x /home
