C CLORIB Distinguished Nov 18, 2010 1 0 18,510 Nov 19, 2010 #1 Hello, My Aus Probe 2 shows 0 Chassis Fan 0 Power Fan 2973 CPU Fan What should I do?
delluser1 Splendid Feb 22, 2007 6,261 0 26,460 Nov 19, 2010 #2 Do you have a fan plugged into either of those headers ? Upvote 0 Downvote
Herr_Koos Splendid Jul 14, 2009 5,020 0 26,460 Nov 19, 2010 #3 I had some bad stability problems with Asus Probe, and eventually removed it completely. I suggest you try CPUID HWmonitor and see what it says. Upvote 0 Downvote
hell_storm2004 Splendid Nov 23, 2009 3,645 2 23,165 Nov 19, 2010 #4 I think the fans are connected directly to the PSU not to the motherboard. You can try any softwares you want you wont get a reading. Upvote 0 Downvote
Herr_Koos Splendid Jul 14, 2009 5,020 0 26,460 Nov 19, 2010 #5 You're correct in that he won't get a reading for the PSU fan, but there should be one for the chassis fan (provided it's connected to the motherboard, of course). Upvote 0 Downvote
