Sound volume goes up and down like a roller coaster
HELP!! My sound volume goes up and down like a roller coaster. Please advise.
OS: Windows XP SP2
Soundcard: Creative Sound Blaster 5.1 VX
4 answers Last reply
More about sound volume roller coaster
  1. Could be problem with the speaker's volume controller. But do check if you have everything set properly, I mean drivers, connectors and the speakers.
  2. get the last sound drive , double check your speakers if u able to try another speaker and see that would be the answer ..
    and try to use the builtin sound card ... and compare between them
  3. Id have to agree with hellstorm, check connections are fine and also re-install drivers, also does it do this with all programs or just a specific one?
    my realtek hdmi and realtek sound chip apparently have driver conflicts and no sound can be delivered. so my main solution now is to use a sound card but i never expect to encounter another problem. i have reinstall the hardware and software but the problem remains.
Sound Cards Windows XP Sound Blaster Components
