Hey people. I've been wanting to build a good gaming pc for a while and since I actually have the money for it now I might as well give it a try. So here's what I have so far.
Approximate Purchase Date: As soon as possible, preferably this week.
Budget Range: About a maximum of 4500 Canadian Dollars (Yes I'm in Canada)
System Usage: Gaming. Lots of gaming. And a bit of internet surfing/watching videos.
Overclocking: Maybe, but preferably not. Might change my mind later though.
SLI or Crossfire: I'm thinking about it.
Additional Comments: I'm basically looking for something that will run any game on max settings without lagging and having a terrible frame rate, and without me having to turn everything else off just to be able to play it. I'd also like to have it stay viable for a while, not have to scrap for something new in just a year or two.
I've got most of the parts down, except for a few I'm sort of leaning between:
GPU: Sapphire Radeon HD 5970 2GB I'm thinking of maybe getting 2 Radeon HD 5970's to Crossfire. Also, is it worth getting the 4GB version? Although to be honest I sort of doubt it.
CPU: Intel Core i7-930 Bloomfield OR Intel Core i7-980X Extreme Edition Gulftown I've heard that the Gulftown isn't worth the incredible price, but those specs seem so tempting. Although that is $700 more...
HDD:Seagate Barracuda XT 2TB 7200 RPM 64MB Cache SATA 6.0GB/s Need lots of space. I always seem to be running out on my laptop even though I only have a fraction of my stuff installed.
RAM: Patriot Viper II Sector 7 Edition 12GB (3 x 4GB) I know this is more expensive than getting 6x2GB (for example G.SKILL PI+ Turbulence 12GB (6 x 2GB) ), but I'm thinking this way theres place for potential upgrade to 24 GB since I'm not using all of the RAM slots.
Case:Cooler Master HAF 932 Black Steel ATX Full Tower I'd rather have a Full Tower instead of a smaller case. Don't know how big the difference is though.
Motherboard: I seriously don't know. But as far as I can tell this seems a good choice:GIGABYTE GA-X58A-UD3R SATA 6Gb/s USB 3.0 ATX Motherboard or maybe some of the similarly priced ASUS? I'm really not sure.
PSU:Corsair AX850 850W 80 PLUS GOLD Active PFC Power Supply Is 850W enough, even if i went for dual 5970's, or would I need More Power! (sorry for the quote, couldn't help myself)
SSD:Micron RealSSD C300 2.5" 128GB SATA III MLC Internal Solid State Drive Might get this, to put my OS on as well as the programs I use the most. From some of the videos I've seen, it can make quite a difference. (If anyone's curious check this video out. It's sort of cool)
Thermal Compound: Arctic Silver 5
As you can see I've done a fair amount of research, but if you guys could tell me which of my maybes (SSD, Crossfire 5970, i7-980x) are good ideas and which probably won't make much difference, I'd be much obliged. Also need major help in the mobo department, as I'm not exactly sure what makes a good motherboard.
Also, would I need a Heatsink and fan, or are the stock ones fine?
Much Thanks in advance,
A first time PC builder (A.K.A. newb).
PS: If the prices seem slightly off to what your used to, remember that this is newegg.ca, not .com, and therefor uses canadian dollars. Sorry for the potential confusion.
