Solved
On board audio gives off strange static. Help?
  • Motherboards
July 15, 2011 9:14:27 PM
So I built my first computer last December. And it went well, but I'm getting strange and annoying static, which is a problem because I leave my earphones on all day regardless of if I have anything playing or not. The static seems to respond to when I click and things, most noticeably when I plug a USB device into the front of the case, then I have to take my earphones off it's so loud. And yes it's not just the case because, even though it's a little clearer when I plug my earphones in the back (directly in the motherboard) I still get the same static, not very lessened. So I was wondering if there's anything I could try to fix this, because I don't wanna have to buy a sound card.
Specs: ASRock M3A770DE motherboard with VIA VT1708S on-board audio
APEX PC-389-C Black Steel ATX Mid Tower Computer Case
Windows 7 (if that matters)
The rest is kind of irrelevant I think.
More about : board audio strange static
a b V Motherboard
July 16, 2011 3:46:44 AM
Is it static, or is it Windows sounds?
m
l
July 16, 2011 3:50:04 AM
No, it's static. Like light and annoying continuous background screeching and static.
m
l
a b V Motherboard
July 16, 2011 3:55:40 AM
My suggestion would be to buy USB headphones/headset, and use that instead.
m
l
July 16, 2011 3:58:22 AM
It's not my headphones either, if that's what you're implying. If the source is the motherboard (which I think it is), I don't think that will help.
m
l
a b V Motherboard
July 16, 2011 4:06:50 AM
Yes it would, as it is the sound card that isn't functioning correctly. Using USB headphones bypasses the sound card completely, so they should not have a problem.
m
l
July 16, 2011 4:09:21 AM
But I used a USB to headphone jack and that didn't do anything, the static was still there. Does that make a difference?
m
l
a b V Motherboard
July 16, 2011 4:29:35 AM
No, so chances are that it is more a driver problem rather than motherboard or sound card. Unless the static is being introduced into the headphone cables, but you'd know if that was the case.
m
l
July 16, 2011 4:39:18 AM
Drivers are up to date, I'm pretty sure. So it's a software problem, not a hardware problem is what you're saying right?
m
l
a b V Motherboard
July 16, 2011 5:02:24 AM
Well, I don't see how it is going to be software, but I don't see that you can get noise out of the USB port unless it is from software. Unless the noise is from the PSU, which could be the case.
m
l
July 16, 2011 5:38:45 AM
Is there a way I can test to see if it's the PSU?
m
l
Best solution
a b V Motherboard
July 16, 2011 6:02:36 AM
VIA sound, that is why you have static. Ive heard static on various onboard audio codecs, your best bet is to get a sound card.
a b V Motherboard
July 16, 2011 8:03:14 AM
Only way to test if it is the PSU would be to replace it, really.
m
l
July 26, 2011 3:24:20 AM
Best answer selected by Markery.
m
l
