My ASUS 19' 1440x900 monitor is the problem.
It's been working fine up until I decided to boot back into my Vista hard drive and use Vista for a while. Here's the story.
The monitor used to work at the said resolution without any blurry areas. I recently (well several months ago now) installed a 2nd hard drive and installed XP Pro on it since I felt nostalgic. I unplugged the Vista HDD and used the HDD that had XP Pro on it for quite some time.
A few weeks ago, I felt like I wanted to use Vista again, so I unplugged the XP Pro HDD and plugged in the Vista HDD.
To my surprise, a small area on the screen is blurry, it's not clear like the rest of the screen. What's odd is, if I boot into XP Pro, it's works fine and there is no blurry area at all. If I hook up the PC to my HDTV, it's fine again, and on that I run 1920x1080. While hooked up to the PC, I can boot into either OS and there are no blurry spots on the TV.
My video card is an ATI HD 3450.
Any solutions?
Please and thank you.
Any solutions?
