hey guys,
i've been looking around for more information and haven't had too much luck.
immediately i want to say I realize i should probably just buy a aftermarket heat sink and cpu fan but still I'm confused about these temperatures, they seem very unreasonable even for stock.
i'm using both speed fan and core temp to read my temps. they both say i am around 53-55C idling temperature. when i am at the bios it idles around 48C.
when i play starcraft 2 it runs around 70-74C. i run it on highest graphics but i did a few tests, and even lowering it, (to medium) didn't make any difference. i have messed around with a few other things such as (in windows 7 control panel) using active vs passive cooling, turning off Q-fan in the bios, doing some cable management, double checking my heatsink/ processor// grease, taking out another harddrive.
also i have even taken a room fan and pointed directly into the case and seen no differences at all ( both aimed through the vents, and with the side off).
also i tried covering up the side panels to force air to come through in a way i thought made more sense. temperatures may have raised 1C but i'm not sure.
yeah.
heres my relevant specs:
(i built this over the weekend, had a veteran computer building friend help me)
cpu Amd Athlon x4 640 3ghz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103871
mobo ASUS M4A87TD/USB3 AM3 AMD
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131651R
graphics (pretty ridiculous, probably contributing alot to heat) Twin Frozr II
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125317
case (comes with back fan and two small fans out the top, which i leave on max power) XCLIO Godspeed 747
http://www.newegg.com/Product/Product.aspx?Item=N82E16811103035
psu
http://www.newegg.com/Product/Product.aspx?Item=N82E16817709027
please any advice would be helpful. i'm assuming im going to have to buy some 120mm fans to fill out the rest of the case but how could that help if using my room fan didn't do anything!
also, i've looked around apparently my processor's max temp is 70C so I am pretty concerned
and it hasn't shut itself off yet, as most people experience with overheating.
help
yeah.
psu
help
