Solved
ATI Driver Problem on 10.6 or more. Please Help
I have been having some problems with my ATI driver setup, when i install any driver past 10.6, it bluescreens at startup and i have to go into safemode to reinstall version 10.4, which works perfectly. Here is my BootLog:
Microsoft (R) Windows (R) Version 6.1 (Build 7600)
7 27 2010 19:40:44.610
Loaded driver \SystemRoot\system32\ntoskrnl.exe
Loaded driver \SystemRoot\system32\hal.dll
Loaded driver \SystemRoot\system32\kdcom.dll
Loaded driver \SystemRoot\system32\mcupdate_GenuineIntel.dll
Loaded driver \SystemRoot\system32\PSHED.dll
Loaded driver \SystemRoot\system32\CLFS.SYS
Loaded driver \SystemRoot\system32\CI.dll
Loaded driver \SystemRoot\system32\drivers\Wdf01000.sys
Loaded driver \SystemRoot\system32\drivers\WDFLDR.SYS
Loaded driver \SystemRoot\System32\Drivers\sptd.sys
Loaded driver \SystemRoot\System32\Drivers\WMILIB.SYS
Loaded driver \SystemRoot\System32\Drivers\SCSIPORT.SYS
Loaded driver \SystemRoot\system32\DRIVERS\ACPI.sys
Loaded driver \SystemRoot\system32\DRIVERS\msisadrv.sys
Loaded driver \SystemRoot\system32\DRIVERS\vdrvroot.sys
Loaded driver \SystemRoot\system32\DRIVERS\pci.sys
Loaded driver \SystemRoot\System32\drivers\partmgr.sys
Loaded driver \SystemRoot\system32\DRIVERS\volmgr.sys
Loaded driver \SystemRoot\System32\drivers\volmgrx.sys
Loaded driver \SystemRoot\system32\DRIVERS\pciide.sys
Loaded driver \SystemRoot\system32\DRIVERS\PCIIDEX.SYS
Loaded driver \SystemRoot\System32\drivers\mountmgr.sys
Loaded driver \SystemRoot\system32\DRIVERS\atapi.sys
Loaded driver \SystemRoot\system32\DRIVERS\ataport.SYS
Loaded driver \SystemRoot\system32\DRIVERS\jraid.sys
Loaded driver \SystemRoot\system32\drivers\fltmgr.sys
Loaded driver \SystemRoot\system32\drivers\fileinfo.sys
Loaded driver \SystemRoot\System32\Drivers\PxHlpa64.sys
Loaded driver \SystemRoot\System32\Drivers\Ntfs.sys
Loaded driver \SystemRoot\System32\Drivers\msrpc.sys
Loaded driver \SystemRoot\System32\Drivers\ksecdd.sys
Loaded driver \SystemRoot\System32\Drivers\cng.sys
Loaded driver \SystemRoot\System32\drivers\pcw.sys
Loaded driver \SystemRoot\System32\Drivers\Fs_Rec.sys
Loaded driver \SystemRoot\system32\drivers\ndis.sys
Loaded driver \SystemRoot\system32\drivers\NETIO.SYS
Loaded driver \SystemRoot\System32\Drivers\ksecpkg.sys
Loaded driver \SystemRoot\System32\drivers\tcpip.sys
Loaded driver \SystemRoot\System32\drivers\fwpkclnt.sys
Loaded driver \SystemRoot\system32\DRIVERS\volsnap.sys
Loaded driver \SystemRoot\System32\Drivers\spldr.sys
Loaded driver \SystemRoot\SysWOW64\speedfan.sys
Loaded driver \SystemRoot\System32\drivers\rdyboost.sys
Loaded driver \SystemRoot\System32\Drivers\mup.sys
Loaded driver \SystemRoot\System32\drivers\hwpolicy.sys
Loaded driver \SystemRoot\System32\DRIVERS\fvevol.sys
Loaded driver \SystemRoot\system32\DRIVERS\disk.sys
Loaded driver \SystemRoot\system32\DRIVERS\CLASSPNP.SYS
Did not load driver @hal.inf,%acpi_amd64.devicedesc%;ACPI x64-based PC
Did not load driver @cpu.inf,%intelppm.devicedesc%;Intel Processor
Did not load driver @msports.inf,%*pnp0501.devicedesc%;Communications Port
Did not load driver ATI Radeon HD 5800 Series
Did not load driver cdrom.SYS
Loaded driver \SystemRoot\System32\Drivers\Null.SYS
Loaded driver \SystemRoot\System32\Drivers\Beep.SYS
Loaded driver \SystemRoot\System32\drivers\vga.sys
Did not load driver RDPCDD.SYS
Loaded driver \SystemRoot\system32\drivers\rdpencdd.sys
Did not load driver RDPREFMP.SYS
Loaded driver \SystemRoot\System32\Drivers\Msfs.SYS
Loaded driver \SystemRoot\System32\Drivers\Npfs.SYS
Loaded driver \SystemRoot\system32\DRIVERS\tdx.sys
Loaded driver \SystemRoot\System32\DRIVERS\netbt.sys
Loaded driver \SystemRoot\system32\drivers\afd.sys
Loaded driver \SystemRoot\system32\DRIVERS\wfplwf.sys
Loaded driver \SystemRoot\system32\DRIVERS\pacer.sys
Loaded driver \SystemRoot\system32\DRIVERS\netbios.sys
Did not load driver Serial.SYS
Did not load driver PStrip64.SYS
Did not load driver Wanarpv6.SYS
Did not load driver TermDD.SYS
Loaded driver \SystemRoot\system32\DRIVERS\rdbss.sys
Loaded driver \SystemRoot\system32\drivers\nsiproxy.sys
Did not load driver mssmbios.SYS
Did not load driver iZ3DInjectionDriver.SYS
Did not load driver EIO_XP.SYS
Did not load driver discache.SYS
Loaded driver \SystemRoot\System32\Drivers\dfsc.sys
Did not load driver blbdrive.SYS
Loaded driver \SystemRoot\system32\DRIVERS\tunnel.sys
Loaded driver \SystemRoot\system32\DRIVERS\HDAudBus.sys
Loaded driver \SystemRoot\system32\DRIVERS\usbuhci.sys
Loaded driver \SystemRoot\system32\DRIVERS\usbehci.sys
Loaded driver \SystemRoot\system32\DRIVERS\Rt64win7.sys
Loaded driver \SystemRoot\system32\DRIVERS\1394ohci.sys
Loaded driver \SystemRoot\system32\DRIVERS\fdc.sys
Loaded driver \SystemRoot\system32\DRIVERS\cdrom.sys
Loaded driver \SystemRoot\system32\DRIVERS\wmiacpi.sys
Loaded driver \SystemRoot\system32\DRIVERS\blbdrive.sys
Loaded driver \SystemRoot\system32\DRIVERS\CompositeBus.sys
Loaded driver \SystemRoot\system32\DRIVERS\mssmbios.sys
Loaded driver \SystemRoot\system32\DRIVERS\AgileVpn.sys
Loaded driver \SystemRoot\system32\DRIVERS\bridge.sys
Loaded driver \SystemRoot\system32\DRIVERS\rasl2tp.sys
Loaded driver \SystemRoot\system32\DRIVERS\ndistapi.sys
Loaded driver \SystemRoot\system32\DRIVERS\ndiswan.sys
Loaded driver \SystemRoot\system32\DRIVERS\raspppoe.sys
Loaded driver \SystemRoot\system32\DRIVERS\raspptp.sys
Loaded driver \SystemRoot\system32\DRIVERS\rassstp.sys
Loaded driver \SystemRoot\system32\DRIVERS\termdd.sys
Loaded driver \SystemRoot\system32\DRIVERS\kbdclass.sys
Loaded driver \SystemRoot\system32\DRIVERS\mouclass.sys
Loaded driver \SystemRoot\system32\DRIVERS\swenum.sys
Loaded driver \SystemRoot\system32\drivers\WmBEnum.sys
Loaded driver \SystemRoot\system32\drivers\WmXlCore.sys
Loaded driver \SystemRoot\system32\DRIVERS\AmdTools64.sys
Loaded driver \SystemRoot\system32\DRIVERS\umbus.sys
Did not load driver @oem35.inf,%hdaudiodevicedescription%;ATI High Definition Audio Device
Loaded driver \SystemRoot\system32\DRIVERS\usbhub.sys
Did not load driver Realtek High Definition Audio
Loaded driver \SystemRoot\system32\DRIVERS\flpydisk.sys
Loaded driver \SystemRoot\System32\Drivers\NDProxy.SYS
Did not load driver \SystemRoot\System32\Drivers\NDProxy.SYS
Loaded driver \SystemRoot\system32\DRIVERS\usbccgp.sys
Loaded driver \SystemRoot\system32\DRIVERS\hidusb.sys
Loaded driver \SystemRoot\system32\DRIVERS\whfltr2k.sys
Loaded driver \SystemRoot\system32\DRIVERS\mouhid.sys
Loaded driver \SystemRoot\system32\DRIVERS\kbdhid.sys
Loaded driver \SystemRoot\system32\DRIVERS\USBSTOR.SYS
Loaded driver \SystemRoot\system32\drivers\WudfPf.sys
Loaded driver \SystemRoot\system32\DRIVERS\bowser.sys
Loaded driver \SystemRoot\System32\drivers\mpsdrv.sys
Loaded driver \SystemRoot\system32\DRIVERS\mrxsmb.sys
Loaded driver \SystemRoot\system32\DRIVERS\mrxsmb10.sys
Loaded driver \SystemRoot\system32\DRIVERS\mrxsmb20.sys
Did not load driver @oem19.inf,%pid_08d7_dd%;Logitech QuickCam Communicate STX
Did not load driver @oem18.inf,%usb\vid_046d&pid_08d7.devicedesc%;Logitech Mic (Communicate STX)
Loaded driver \SystemRoot\System32\Drivers\LUsbFilt.Sys
Loaded driver \SystemRoot\system32\DRIVERS\LHidFilt.Sys
Did not load driver @oem45.inf,%logitech_raw_pdo%;Logitech Driver Interface
Loaded driver \SystemRoot\System32\Drivers\fastfat.SYS
7 28 2010 18:01:39.610
Loaded driver \SystemRoot\System32\DRIVERS\RDPCDD.sys
Loaded driver \SystemRoot\system32\drivers\rdprefmp.sys
Loaded driver \SystemRoot\System32\Drivers\avgtdia.sys
Loaded driver \SystemRoot\system32\DRIVERS\serial.sys
Loaded driver \SystemRoot\system32\drivers\pstrip64.sys
Loaded driver \SystemRoot\system32\DRIVERS\wanarp.sys
Loaded driver \??\C:\Program Files (x86)\iZ3D Driver\Win64\S3DInjectionDriver.sys
Did not load driver \??\C:\Windows\system32\drivers\EIO64_XP.sys
Loaded driver \SystemRoot\System32\drivers\discache.sys
Loaded driver \SystemRoot\System32\Drivers\avgmfx64.sys
Loaded driver \SystemRoot\System32\Drivers\avgldx64.sys
Loaded driver \SystemRoot\system32\DRIVERS\intelppm.sys
Loaded driver \SystemRoot\system32\DRIVERS\atikmdag.sys
Loaded driver \SystemRoot\System32\drivers\dxgkrnl.sys
Loaded driver \SystemRoot\system32\DRIVERS\atikmpag.sys
Loaded driver \SystemRoot\system32\DRIVERS\serenum.sys
Loaded driver \SystemRoot\System32\Drivers\a7h1xozg.SYS
Did not load driver \SystemRoot\System32\drivers\vga.sys
Loaded driver \SystemRoot\system32\DRIVERS\LVUSBS64.sys
7 28 2010 18:02:27.610
6 answers Last reply Best Answer
More about driver problem more help
  1. By the way, I forgot to mention, I have two 5850's in CF and dual monitors, does that effect it?
  2. Still, no-one replied, anyway i fixed it myself by fiddling aroung with a program called Autoruns.exe, works quite well. Thanks Everyone...
  3. Does anyone know the program Autoruns, I think it was one of the best programs invented, it fixed my problem straight away, even though I didn't know what I was doing... Thanks again everyone... Oh and vTL123 reading this, LOL!
  4. Best answer
    Try fiddling around called Autoruns.exe .It should help solve the problem. Hope it answers your question
  5. Thanks best answer, (he told me beforehand)...
  6. Best answer selected by Scanlia.
Radeon Drivers System32 ATI Graphics
