I have cloned several systems to SSD's. It all works the same, just faster.
As for OCZ, just ensure you have the latest firmware and things should be good.
Please ensure that your SATA ports are set to AHCI before using the SSD.
This brings up another concern, if your are in IDE mode at this time, the swap will lead to blue screens and you will need to do a registry change to fix it BEFORE making the change to the SSD.
Other things to have ready.
Windows DVD or Windows repair DVD. The cloning process depending on the drive can lead to an blue screen about a missing device. This is because the system reserved partition tells the system what drive/partition to boot from and the swap of a drive sometimes messes it up(better software does not have this problem). Windows "Start-up Repair" will fix it up very fast.
You may also wish to have either another system handy in case you want to rebuild the BCD entry(the Windows start-up repair should do this for you). It never hurts to be ready for anything.
On advantage you have is that as long as you do erase the hard drive you can actually boot it and edit the BCD on the SSD if you have to
. You do NOT want to erase the hard drive until you are 100% sure the clone went well.
It does not hurt to have a copy of GParted on hand. It is a linux based partition tool that can be used if for some reason your clone is not aligned.
http://lifehacker.com/5837769/make-sure-your-partitions-are-correctly-aligned-for-optimal-solid-state-drive-performance
I know it seems like a lot, but its not too bad.
Clone(with your software of choice. I have used easus todo backup free and it worked, but DID create an unaligned partition and needs bcd editing or startup repair).
Remove hard dive and try to boot.
Error? Try windows startup repair.
Boot. Good?(if not post back and we will use easyBCD to edit the SSD's boot loader)
Check Alignment. use AS SSD to see if under the controller it has another line that says OK. If it is RED, you most likely need to align the drive.
http://www.softpedia.com/dyn-postdownload.php?p=216352&t=0&i=1
The link above lists how to align the drive with GParted.
Here is the kicker, if you have had to align, you will need to run the repair again.
Just so you know, not all software has these issues. I have not cloned enough SSD's, but I am almost sure any SSD/hard drive that have Acronis software will do ALL(or damn near all) the work for you.
Remember at this point, you have not messed with the Hard drive meaning that you can always use the other drive to fix any BCD errors(bootloader) without much trouble.
