Hey there everyone,
Let me get it out of the way and tell you i'm a noob at PC building.
I just started my first build. So far I have:
-AMD phenom ii x4 955 BE
-Asus M4A785TD-V EVO 785G RT Motherboard
-2 gb G.Skill DDR3 RAM
-OCZ 700 Watt Power Supply
-Lancool case w/3 fans
I have put that all together and checked for post. It powered up, but went to some screen about not having the proper boot drive or something like that. I assume it was because I have not CD or HDD hooked up.
Now the questions.
First of all, I am broke right now and don't have enough $$$ to buy a new hard drive and CD drive yet. I was wondering if I could use my old CD and HDD out of my previous computer. I'm sure you could just pop in the CD drive, but is it recommended that I wipe my old HDD before installing it into my new PC? Should I even do it at all? I don't want to ruin anything, but i'm excited to mess around with the new one. I would be using my old HDD as my new primary (and only!) HDD. Is this ok to do?
Second, I don't know what to expect when turning the PC on for the first time, is there anything in particular a first time builder like myself should look for or do first thing? I don't know much about BIOS, but I don't think i'll have too much of a problem with it.
Third, my cpu's heatsink seemed difficult to snap into place, I felt like I used a lot of force to get it set. Is that normal? There seemed to be 2 different ways it would snap on and no directions to tell me if one way was better than the other.
Thanks in advance for all your help!
Now the questions.
