Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > Need advice, hoping to order soon but pretty clueless
Forum Systems : New Build Need advice, hoping to order soon but pretty clueless
Hi guys,
First of all, this is the first time i'm ever building a PC myself, so I was hoping to get a few people to check out the build before clicking alot of buy buttons.
Some of the pieces I chose were because of where I live, which is Japan. Most PC parts can be purcahsed over here, but a few things such as cases, are tricky. I'm sure i'm bound to have made a few newbie mistakes, so be gentile haha.
Budget: 700 - 1000 dollars (hopefully closer to 700 so I can get a monitor too for under 1000
Case : Coolmaster Cm690
http://www.newegg.com/Product/Prod [...] -_-Product
Mobo : GIGABYTE GA-P55-USB3 LGA 1156 Intel P55 USB 3.0 ATX Intel Motherboard
GPU : GIGABYTE GV-R585OC-1GD Radeon HD 5850
http://www.newegg.com/Product/Prod [...] R585OC-1GD
Processor : Intel Core i5-750 Lynnfield 2.66GHz LGA 1156 95W Quad-Core Processor BX80605I5750
Ram : CORSAIR XMS3 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666)
http://www.newegg.com/Product/Prod [...] X4G1333C9A
I'm really not too sure about what PSU I need at this point. I'm pretty clueless. Newegg's PSU tool calculated about 475 for my setup as the req watt, but should I go over that? I was thinkin about this one:
CORSAIR CMPSU-550VX 550W ATX12V V2.2 SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
http://www.newegg.com/Product/Prod [...] 6817139004
Any help at all can be appreciated. I'm open to all suggestions.
Thanks a bunch
Mahou
Reply to Mahou86
I would go for the 650w corsair for some breathing room. Everything else looks ok, since you're limited by your vender.
Reply to o1die
It all looks good including your PSU choice.. However, you need to be sure that you wont be going for a multi GPU setup ever as the secondary PCI express slot on that motherboard runs at x4 speed.. On a side note, try looking out for RAM which has better timings than that Corsair.. Look out for G-Skil ripjaws..
Reply to Emperus
I was looking at the g-skil, but I can't buy it here. I'll try to find a comparable speed though. I chose the Corsair to keep the cost down.
Another question, if I can get the I5 760 for about 8 bucks more, should I jump on it? I noticed it's not that much cheaper.
Reply to Mahou86
Sorry for the Japanese link, but is this a comparable set?
http://www.twotop.co.jp/details/?j [...] 47856&pd=0
Reply to Mahou86
http://www.twotop.co.jp/details/?j [...] 06248&pd=0
This would be a good investment.. And for 8 bucks extra, surely grab on to the i5 760..
Reply to Emperus
This topic has been moved from the section CPU & Components to section Systems by Mousemonkey
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
Okay, found the ripjaw ram actually! Took a hell of alot of searching, but it's only 10 bucks over the current selected ram.
Here is the tentative final setup:
Case : Antec Three Hundred AB
http://www.newegg.com/Product/Prod [...] 6811129042
GPU : HIS H585FN1GD Radeon HD 5850
http://www.newegg.com/Product/Prod [...] llFullInfo
Processor : Intel Core i5-760 Lynnfield 2.8GHz 8MB L3 Cache LGA 1156 95W Quad-Core Desktop Processor BX80605I5760
Ram : G.SKILL F3-12800CL7D-4GBRM
PSU : CORSAIR CMPSU-650TX 650W
http://www.newegg.com/Product/Prod [...] MPSU-650TX
Total = 91475
Any final thoughts?
Reply to Mahou86
There are 1567 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Gigabyte z77x not working with corsair tx750?
By smorizio, 2 hours ago:
[quotemsg=2611689,1,1216211]hi guys i need some help, im not getting any power to the...
Best offers
Top experts
