Does this case have good cable management? And space?
Cooler Master Storm Scout( http://www.newegg.com/Product/Product.aspx?Item=N82E16811119196&cm_re=storm_scout-_-11-119-196-_-Product ). Does it have good airflow, cable management especially, space for future upgrades, and such? Also, if you have a cheaper case...please please please please PLEASE suggest it.
~Pyro
12 answers Last reply
More about does case good cable management space
  1. Hi pyrogx,
    From the looks of it it is a nice mid-tower case, there are probably quite a few nice cases in that price range. It would seem to have good airflow with 2x140mm fans and 1x120mm and an option to add 2 more to the side. And just looking at the pictures provided on Newegg it has a very nice cable management also, probably one of the better cases for that. And as long as your not going to put alot of hard drives or want anymore than 2 GPU's you will have plenty of space.
    Have you read any of the reviews on Newegg? They can provide you with alot of good information about the quality and abilities of the case, also did you watch the video? Or you can also search the web for a pro-review of the case.
  2. mosox said:
    I have looked at that case, and I do have a couple of threads that turned me away from it. Just the fact that it will be tight when cables are routed behind the mobo. Any other cases with great management? :\
  3. Cooler Master HAF 912
  4. For your $80 range i can recomend you the HAF 922 at $90 ( i have one) http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197&cm_re=haf_922-_-11-119-197-_-Product
    it has A LOT of rom, very good cable management (this is for you are looking) and a very Good air flow, and many other things.
    If u wanna save more money, i can recomend you the new haf 912 for $ 60
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233&Tpk=haf%20912
    Its the little brother of HAF 922, but less, but its great, its HAF (High Air Flow), very good cable management, plenty of room (can fit a RADEON 5970 without problem), 2.5 SSD, etc.
    I hope this can help you
  5. Antec 300 Illusion is going for $50 at Newegg.com right now, but there is no cable managment, its all up to you to be creative or mod the case. But one thing is has going for it is it comes loaded with nice fans and can keep your system nice and cool. Looks darn good too. :)
    [UPDATE] Here is the link to the 300 Illusion: http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
    the antec illusion is the best case under $70, at under $50 its a steal
  7. ^ Hes a spammer :fou: posting advertisements, dont worry I have reported him to the forum moderators.
  8. duk3 said:
    The only thing that turns me away from that case is the Front I/O is on the top of the case. But i guess its not a big deal, actually helpful, since my desktop when it is built will be on the floor..hmm...
Power Supplies Cooler Master Cases Management Cable Components Product
