Solved
Motherboard and RAM help
Hello,
P8H61-MLE vs DH61WW
Which one of the two is better in terms of price/features ratio?
and what is the difference b/w these two:
CORSAIR DDR3 2GB-1333BUS VALUE SELECT & CORSAIR DDR3 2GB-1333BUS XMS3
is the xms3 worth the extra bucks?
3 answers Last reply Best Answer
More about motherboard help
  1. Best answer
    For the ram, check the timings. Lower cas number is more efficient. Avoid value ram. Both boards will work fine, but the asus has a dvi port and newer software utilities. Asus has been hit or miss on quality, but I can't predict how well this board works. Read some newegg reviews; they're as good as any.
  2. Best answer selected by imrn85.
  3. thanks!
Asus DDR3 Corsair Motherboards Product
