Solved
Building a small Computer and need advice on power and heat.
So I want to build a very small computer using a thin box to install under my TV to steam movies. I must work with a 300watt supply, so I need low power consuming components that also do not build up much heat.
I'm considering a Sempron or Celeron processor, but I wanted to know everyone's thoughts or experience with these smaller cpus. Thanks.
4 answers Last reply Best Answer
More about building small computer advice power heat
  1. Low power Athlon II or Core 2 @ 2Ghz should be more than ample and not too big a power draw, integrated gpu is more than enough aslong as it supports HDMI.
  2. any processor should work just make sure the video card/gpu supports acceleration of 1080p if that's important to you.
  3. Best answer
    Which is why I recommend an athlon IIx2 with a motherboard that has integrate radeon 4200 graphics. Should be able to handle everything you throw at it. Since you don't need a dedicated graphics card, pretty much anything you decide on should fit into an under 300W power supply.
    Heat should not be an issue with that setup. A sempron would also work fine (the 140).
  4. Best answer selected by ahthurungnone.
CPUs Computer
