I think I have a hard drive problem
I booted up and logged in and it got stuck on the preparing desktop screen. I waited and after about 3 minutes my screen popped up black with nothing on it except these 2 messages....
http://imgur.com/vBB5z
http://imgur.com/MJANQ
I restarted 3 times before everything loaded as normal......I have an ssd and even when it boots up properly it has been going slow for an ssd. I have a Kingston Hyper X 3K...it has been working fine for the 3 months prior that I have owned it.
any ideas? is my ssd already going bad?
6 answers Last reply
More about hard drive problem
  1. Sounds like it's time to back up all your important data and do a clean re install of Windows IMO.
  2. I have most of my stuff saved on my secondary back up drive......I just thought I would check and see if anyone knows of an easy fix or why this is happening before I do that
  3. run SFC /scannow in a elevated command prompt for starters.
    did that already..it said it encountered a problem that could not be fixed and I have no idea how to read the logs
  5. If it can't fix it then I forsee a Windows reinstall in your future =D
    I gave in and reinstalled.....every couple of boots I still get a blue screen that says like system dump to memory or something....then my computer reboots and it usually works the second time....could I have bad memory?
SSD Hard Drives Storage
