Logitech Z2300 400W speakers or Buy another HD4870+ Power supply
Okay so guys im very unsure on what to get as im looking to treat myself:
My Rig;
Intel Core 2 Quad Q9300 2.5Ghz @3.4Ghz
MSI P45 Platinum
4GB 800Mhz Corsair Ram
ATI Radeon HD4870
500W Power supply.
1)So should i get another HD4870 my motherboard supports crossfire+ A new 750w OCZ Powersupply
2) Logitech Z2300 Speakers 2.1 400w my current ones are x-530 140w
3)Corsair H50 Hydro Cooler for my cpu. (idle 42c load 69c) current fan is artic cooler freezer pro 7
Much appreciated ;D :bounce:
Graphics card Master
Power supply Expert
What power supply do you have now (brand)? Another 4850 wouldn't be a bad idea depends on what you can do with your current 4850 (if you could sell it for anything) and if you want DX11 or not.
Your CPU cooler is fine, but if I was going to upgrade WAIT for the H70, it comes out soon. Also Noctua NH-D14 performs BETTER then the H50, so look into that too. But your temps are not bad.
Ask the community
