Solved
Does the size concerned to speed
SSD is fast right if we combine them with a mechanical hard drive, but if does it perform if the size of the SSD is bigger?
3 answers Last reply Best Answer
More about does size concerned speed
  1. Best answer
    Generally, yes. Larger capacity SSDs have more NAND chips in them so their maximum Read/Write speeds are higher than smaller capacity SSDs.
  2. Best answer selected by chamnaplong.
  3. thanks
SSD Hard Drives Storage
