Microphone not working head phones working
hi pls give a solution for the headphones connected working well but the microphone is not working with windows vista ultimate,i use logitech headset,
1 answer Last reply
More about microphone working head phones working
  1. Logitech makes a lot of headsets, please be more specific.
    If you have one connector for the earphones and a separate connector for the microphone, and if you are using the front panel jacks . . . try using the rear panel jacks instead.
    If that works your front panel micorphone jack is bad. if it doesn't work your headset is bad.
Sound Cards Phones Microphone Headphones Components
