Dedicated physx card help
hi im looking into getting a Ageia PhysX card.
my question is should i get the BFG Ageia PhysX card or just the Ageia's PhysX card.
also im a bit of a newbie to pc's and i hope someone can awnser my second question
what slot does a Ageia PhysX card take up. im guessing it isnt a graphic card slot, so do most motherboards have a seperate port for them.
thanks
3 answers Last reply
More about dedicated physx card help
  1. I think you should get some new GeForce card for the PhysX. They all need a PCI express slot and it should be fine.
    Just let us know your budget.
  2. I wouldn't bother with the Ageia PhysX card, Nvidia are no longer updating the drivers and have discontinued them.
  3. thanks for the replys
    im only intrested because they are so cheap
    thanks for the awnsers but i kind of need help with what slot it goes in.
    another thing is do the games that use Ageia PhysX do they also use nvidia physx.
    thanks
CPUs Graphics Cards Physx Motherboards
