Question about fans/cooling
Last response: in Systems
Hi I have a question about my system,
I am using Hardware sensors monitor 4.5. In the program it says I dont have any temp readings for Cpu1 but there is one for CPU2 Cpu0 Core. Also there is no reading for CPU1 fan... Is that normal that it would skip 1 and then go to 2? Also is a reading of 31 C for CPU2 and 29 for CPU0 good?
Thanks!
More about : question fans cooling
Homebuilt system Master
Can you post a screen shot along with your system specs like motherboard and CPU? I have never seen what you are describing before so i feel like a picture will be very helpful
Oh sorry, my motherboard is MSI 785GM-E51 , cpu is AMD Phenom II X4 965 3.40 ghz
here is the screenshot of the monitoring software, why is there no reading for things like CPU 1? And are the temperatures normal? Thanks!
Im not familiar with that software, i usually use HW Monitor. Its probably just a software glitch, since it shows you a CPU0 core, and no other cores it probably misinterpreting the sensors on the board.
Ask the community
