Advice on Hybrid Power Graphics card
I want the best budget (around $100) graphics card which supports Hybrid Power technology. My motherboard is ASUS M3N78-EM and processor is AMD athlon X2. Can someone help me with it? I shall really be thankful.
I am a casual gamer and play racing games most of the time. Thats why I want a Hybrid Power capable card. I will upgrade the power supply as per requirement.
4 answers Last reply
More about advice hybrid power graphics card
  1. What power supply do you have? Is the 100 dollars in your budget for the GPU AND the PSU together?
    Anyway this is a good 100 dollar card....
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814261062&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=3463938&SID=
  2. $100 for GPU only is the budget. Is tht card Hybrid Power ready?
  3. Hybrid Power you don't even need, Nvidia has started using Adaptive Power instead of Hybrid Power. Hybrid Power would litterally shut your graphics card down and use onboard graphics.
    You can use the Adaptive Power setting if you really want in Nvidia with that card.
  4. 90% of time I only surf internet and chat. so i dont wanna waste like 200+ watts on the graphic card all the time.
Graphics Cards Power Graphics Product
